BootlegMIC with iPhone 5 - How Should I Start Tweaking?
Hi all,
Built a few bootlegMICs from kits, not much of an tinkerer but this looked like too good a project to pass up. Needless to say, now I'm looking for more things to do with my soldering iron. The following will be one such thing, but I need a little help figuring out where to begin.
I've built three bootlegMICs, and all three work with the iPhone 4 and 4S. I recently purchased an iPhone 5, and it doesn't quite work with the iPhone 5. The resulting recordings sound as if there's massive interference of some kind up until there's enough signal coming from the mic to cut through the noise. Then, it's nice and clear. Until the signal goes away. Then interference-y whine again.
I've looked at the schematic of the mic on the wiki, and it makes enough sense - now I'm guessing that there's some incompatibility between the drain resistor inside the phone and the gain of the mic itself, but from there I'm not sure how to begin experimenting to figure out where the iPhone 5 needs it. Any tips from a more experience maker who might be able to give me Point A so I've got somewhere to start from on my quest to Point B?
Thanks in advance, and thanks for making these plans and kits available!
