How can I get adc results and use in loop()
I'm korean newbie of maple and this audio codec shield.
First of all, I wanna upload my algorithm to the maple board. My project needs two mic inputs so I'm using audio codec shield.
I'm gonna put my algorithm in loop(). Actually I don't need analog outputs, just need Adc results and I need to use adc results(as 44.1kHz sampling rate) in my code.
Let's see my code.
I'm thinking that mod0_value, mod1_value are adc results and these values gonna be inputs of my algorithm.
But I'm wondering i'm right and If I use mod0_value, mod1_vlaue in the loop, these values are updated or not.
Please give me any comments or suggestions. It would be really helpful for me.
Actually what I want is getting adc results and using these results as the input of my algoritm in loop()
All the best.
Let's see my code.
// even though the function is mono, the codec requires stereo data
unsigned int mod0_value = 0;
unsigned int mod1_value = 0;
// I'm gonna put my algorithm in here
void AudioCodec_interrupt() {
// you dont need to reti() with Maple
}I'm thinking that mod0_value, mod1_value are adc results and these values gonna be inputs of my algorithm.
All the best.
